Developer documentation | Axl-2.5.1
axlFieldParametricNormalVector.cpp
Go to the documentation of this file.
1 /* axlFieldParametricNormalVector.cpp ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14 #include <sstream>
15
17 #include "axlAbstractProcess.h"
18
19 #include "axlPoint.h"
20 #include "axlMesh.h"
21
22 #include <dtkCoreSupport/dtkGlobal.h>
23
24 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
25 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
26
29
30 class axlFieldParametricNormalVectorPrivate
31 {
32 public:
36
38 };
39
40 // /////////////////////////////////////////////////////////////////
41 // axlFieldParametricNormalVector implementation
42 // /////////////////////////////////////////////////////////////////
43
45
49 {
50  d->input = NULL;
51  this->setObjectName(this->identifier());
55 }
56
57
58
60
64 {
65  delete d;
66
67  d = NULL;
68 }
69
70
72
75 double *axlFieldParametricNormalVector::vector(double u, double v, double w)
76 {
77  if(!(this->kind() == Vector)) {
78  qDebug() << "Getting vector value on non vector field.";
79  return NULL;
80  }
81  axlMesh mesh = d->input->eval(u,v,1);
82  axlPoint *deriv1u = new axlPoint() ;
83  mesh.vertex(1, deriv1u);
84  axlPoint *deriv1v = new axlPoint();
85  mesh.vertex(2, deriv1v);
86  axlPoint *normalPoint = axlPoint::crossProduct(deriv1u, deriv1v);
87  double *normal = normalPoint->coordinates();
88  //qDebug() << Q_FUNC_INFO << u << " " <<v << " " << normal[0] << " " << normal[1]<<" " << normal[2] ;
89
90  return normal;
91
92 }
93
94
95
97
101 {
102  return "axlFieldParametricNormalVector";
103 }
104
105
107
111 {
112  QString qstr;
113
114  qstr.append("axlFieldParametricNormalVector : \n");
115  qstr.append("Type : Double ");
116  qstr.append(";Kind : Vector ");
117  qstr.append(";Support : Point");
118
119
120  return qstr;
121
122 }
123
124
126
130  if(dynamic_cast<axlAbstractSurfaceBSpline*>(data))
131  d->input = dynamic_cast<axlAbstractSurfaceBSpline*>(data);
132 }
133
134
136
140
141  return d->input->startParam_u();
142
143 }
144
145
147
151  return d->input->startParam_v();
152 }
153
154
156
160
161  return d->input->endParam_u();
162 }
163
164
166
170
171  return d->input->endParam_v();
172 }
173
174
175
177
181
182  return d->input->numSamples_u();
183 }
184
186
190  return d->input->numSamples_v();
191 }
192
193
194
196
200  return d->input->numSamples_u()*d->input->numSamples_v();
201 }
202
203
204
207
211 {
212  emit updated();
213 }
214
215 // /////////////////////////////////////////////////////////////////
216 // axlFieldParametricNormalVector documentation
217 // /////////////////////////////////////////////////////////////////
218
225 // /////////////////////////////////////////////////////////////////
226 // Type instanciation
227 // /////////////////////////////////////////////////////////////////
228
230 {
232 }
233
234
Class axlPoint defines 3D points.
Definition: axlPoint.h:34
int size(void)
Returns the number of values evaluated for this BSpline field on each samples of the input BSpline...
double start_v(void)
Returns the first parameter value of the field.
double * coordinates(void) const
Returns coordinates of this point.
Definition: axlPoint.cpp:445
double numbersample_v(void)
Returns the number of parameters.
axlMesh * mesh(void)
Return the mesh of that object is computed.
double end_v(void)
Returns the last parameter value of the field.
void setSurface(axlAbstractData *data)
Sets the BSpline on which the BSpline field is applied.
virtual Kind kind(void)
void vertex(const int &ind, double vertex[3])
set vertex values of vertices with index ind.
Definition: axlMesh.cpp:322
dtkAbstractData * createaxlFieldParametricNormalVector(void)
double end_u(void)
virtual void setType(Type type)
Sets the type of the field which can be either int, float or double.
Class axlFieldParametricNormalVector defines an API for field which owns a BSpline Surface as a funct...
double * vector(double u, double v, double w=0.)
Returns the value of the spatial field at the coordinates point entered.
virtual void setSupport(Support support)
double start_u(void)
Class axlAbstractFieldParametricSurface defines an API for parametric field.
static axlPoint crossProduct(const axlPoint &lhs, const axlPoint &rhs)
Returns the cross product between lhs (coords) and rhs (coords).
Definition: axlPoint.cpp:485
virtual void setKind(Kind kind)
Sets the kind of the field which can be either scalar, vector or tensor.
QString identifier(void) const
Returns the identifier of the field "axlFieldParametricNormalVector".
double numbersample_u(void)
virtual ~axlFieldParametricNormalVector(void)
Destroys a Bspline field.
Class axlAbstractData defines an API for all type of axel data.
QString description(void) const
Returns the description of the field.
Class axlMesh defines a piecewise-linear 3D object.
Definition: axlMesh.h:41
