#include <axlSurfaceRevolution.h>
Public Member Functions | |
| axlSurfaceRevolution (QObject *parent=0) | |
| axlSurfaceRevolution (axlLine *axe, QList< axlAbstractCurve * > curves, double theta1, double theta2, QObject *parent=0) | |
| ~axlSurfaceRevolution () | |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| axlLine * | getAxe () |
| QList< axlAbstractCurve * > | getCurves () |
| double | getStartAngle () |
| double | getEndAngle () |
| int | countCurve () |
| axlAbstractCurve * | getCurve (int id) |
| void | setAxe (axlLine *line) |
| void | setAxe (axlPoint *point1, axlPoint *point2) |
| void | setCurves (QList< axlAbstractCurve * > curves) |
| void | setStartAngle (double ang) |
| void | setEndAngle (double ang) |
| void | setAngle (double startAngle, double endAngle) |
| axlSurfaceRevolution & | operator= (const axlSurfaceRevolution &other) |
Public Member Functions inherited from axlAbstractSurface | |
| axlAbstractSurface (void) | |
| virtual | ~axlAbstractSurface (void) |
| virtual int | dimension (void) const |
| virtual axlMesh * | toAxlMesh (void) |
| virtual void * | surface (void) |
Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object. More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object. More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed. More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object. More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Definition at line 17 of file axlSurfaceRevolution.h.
| axlSurfaceRevolution::axlSurfaceRevolution | ( | QObject * | parent = 0 | ) |
Definition at line 31 of file axlSurfaceRevolution.cpp.
| axlSurfaceRevolution::axlSurfaceRevolution | ( | axlLine * | axe, |
| QList< axlAbstractCurve * > | curves, | ||
| double | theta1, | ||
| double | theta2, | ||
Definition at line 45 of file axlSurfaceRevolution.cpp.
| axlSurfaceRevolution::~axlSurfaceRevolution | ( | ) |
Definition at line 61 of file axlSurfaceRevolution.cpp.
| int axlSurfaceRevolution::countCurve | ( | ) |
Definition at line 177 of file axlSurfaceRevolution.cpp.
virtual |
Definition at line 96 of file axlSurfaceRevolution.cpp.
| axlLine * axlSurfaceRevolution::getAxe | ( | ) |
Definition at line 126 of file axlSurfaceRevolution.cpp.
| axlAbstractCurve * axlSurfaceRevolution::getCurve | ( | int | id | ) |
Definition at line 191 of file axlSurfaceRevolution.cpp.
| QList< axlAbstractCurve * > axlSurfaceRevolution::getCurves | ( | ) |
Definition at line 136 of file axlSurfaceRevolution.cpp.
| double axlSurfaceRevolution::getEndAngle | ( | ) |
Definition at line 152 of file axlSurfaceRevolution.cpp.
| double axlSurfaceRevolution::getStartAngle | ( | ) |
Definition at line 144 of file axlSurfaceRevolution.cpp.
virtual |
Definition at line 116 of file axlSurfaceRevolution.cpp.
| axlSurfaceRevolution & axlSurfaceRevolution::operator= | ( | const axlSurfaceRevolution & | other | ) |
Definition at line 73 of file axlSurfaceRevolution.cpp.
| void axlSurfaceRevolution::setAngle | ( | double | startAngle, |
| double | endAngle | ||
Definition at line 216 of file axlSurfaceRevolution.cpp.
| void axlSurfaceRevolution::setAxe | ( | axlLine * | line | ) |
Definition at line 164 of file axlSurfaceRevolution.cpp.
Definition at line 172 of file axlSurfaceRevolution.cpp.
| void axlSurfaceRevolution::setCurves | ( | QList< axlAbstractCurve * > | curves | ) |
Definition at line 182 of file axlSurfaceRevolution.cpp.
| void axlSurfaceRevolution::setEndAngle | ( | double | ang | ) |
Definition at line 206 of file axlSurfaceRevolution.cpp.
| void axlSurfaceRevolution::setStartAngle | ( | double | ang | ) |
Definition at line 196 of file axlSurfaceRevolution.cpp.
