Using Axl from another application¶
In this section, we illustrate how Axl library and data can be used from an external application. The corresponding
file is axl/test/axlExpl/torus.cpp.
Header files¶
To define the plugin manager and the objects to be used, some header files need to be included:
#include <axl-config.h> // For AXL_PLUGIN_DIR, AXL_DATA_DIR
#include <axlCore/axlReader.h> // Generic data reader
#include <axlCore/axlWriter.h> // Generic data writer
#include <axlCore/axlFactoryRegister.h> // Factory of data
#include <dtkCoreSupport/dtkPluginManager.h> // Plugin manager
#include <axlCore/axlPoint.h> // Definition of axlPoint
#include <axlCore/axlTorus.h> // Definition of axlTorus
The file axl-config.h define the macro AXL_PLUGIN_DIR corresponding to the folder of the plugins and
AXL_DATA_DIR corresponding to the folder of the data.
Loading the plugins¶
We set up the plugin manager and load the plugins:
// // Loading of Axel plugins
// dtkPluginManager::instance()->setPath(AXL_PLUGIN_DIR);
// dtkPluginManager::instance()->initializeApplication();
// dtkPluginManager::instance()->initialize();
// axlFactoryRegister::initialized();
Reading data¶
We read the file torus.axl from the folder AXL_DATA_DIR:
//Reading input file
qDebug()<<"Reading file"<<QString(AXL_DATA_DIR)+"/torus.axl";
axlReader *obj_reader = new axlReader();
obj_reader->read(QString(AXL_DATA_DIR)+"/torus.axl");
QList<axlAbstractData *> list = obj_reader->dataSet();
The list of objects, which have been read, is list.
Manipulating data¶
We output the description of the first object in the read list, which should be a torus. We cast it into an axlTorus and get its center. The color of the center point and its size are changed:
// Print description of list[0]
qDebug()<<list.at(0)->description();
//Convertion of generic object to a Torus
axlTorus* axltorus = dynamic_cast<axlTorus*>(list.at(0));
axlPoint* P= axltorus->centerPoint();
P->setColor(1.0,0,0);
P->setSize(0.08);
qDebug()<< " Point:"<<P->x()<<P->y()<<P->z();
Saving data¶
In the last steps, we save all the objects, which have been read and the center point in the file tmp.axl:
//Writing output file
axlWriter *obj_writer = new axlWriter();
foreach(axlAbstractData* o, list)
obj_writer->addDataToWrite(o);
obj_writer->addDataToWrite(P);
