6 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
    9 class axlCompositeCurveConverterPrivate
   28     return "Converter from axlCompositeCurve to axlMesh";
   33     return "axlCompositeCurveConverter";
   38     return QStringList() <<
"axlCompositeCurveConverter" <<
"axlCompositeCurve";
   47     return dtkAbstractDataFactory::instance()->registerDataConverterType(
"axlCompositeCurveConverter", QStringList(),
"axlMesh",
createaxlCompositeCurveConverter);
   51 void axlCompositeCurveConverter::addMesh2Mesh(
axlMesh& mother_mesh,
axlMesh *child_mesh)
   53     QVector<axlMesh::Edge> edge_of_child_mesh = child_mesh->
edgeSet();
   55     qDebug()<<
"count_vertex = "<<count_vertex;
   64     for(
int i = 0; i<edge_of_child_mesh.size(); i++)
   66         QVector<int> temp(edge_of_child_mesh.at(i).size());
   68         for(
int j = 0; j < edge_of_child_mesh.at(i).size(); ++j)
   70             temp.insert(j, edge_of_child_mesh.at(i).at(j) + count_vertex );
   73                 qDebug()<< edge_of_child_mesh.at(i).at(j)<<
" ---> "<<edge_of_child_mesh.at(i).at(j) + count_vertex;
   81 axlPoint *
rotatePoint(
double a,
double b,
double c,
double x,
double y,
double z,
double u,
double v,
double w,
double alpha)
   84     qreal a1 = (a*(qPow(v,2)+qPow(w,2))-u*(b*v+c*w-u*x-v*y-w*z))*(1-qCos(alpha))+x*qCos(alpha)+(-c*v+b*w-w*y+v*z)*qSin(alpha);
   85     qreal a2 = (b*(qPow(u,2)+qPow(w,2))-v*(a*u+c*w-u*x-v*y-w*z))*(1-qCos(alpha))+y*qCos(alpha)+(c*u-a*w+w*x-u*z)*qSin(alpha);
   86     qreal a3 = (c*(qPow(u,2)+qPow(v,2))-w*(a*u+b*v-u*x-v*y-w*z))*(1-qCos(alpha))+z*qCos(alpha)+(-b*u+a*v-v*x+u*y)*qSin(alpha);
  105     double n = point.
norm();
  160     QList<axlPoint *> result;
  162     if(
axlLine *line = dynamic_cast<axlLine *>(curve))
  164         result.append(line->firstPoint());
  165         result.append(line->secondPoint());
  167     else if(
axlCircleArc *ca = dynamic_cast<axlCircleArc *>(curve))
  179         for(
int i = 0; i<=40;i++)
  186         double step = (curvepara->endParam()-curvepara->startParam())/40;
  187         for(
int i = 0;i<41;i++)
  189             result.append(
new axlPoint(curvepara->eval(curvepara->startParam()+i*step)));
  203     if(d->data->getCase())
  205         QList<QList<axlPoint *> > $list;
  206         for(
int i = 0; i<d->data->count_curve(); ++i)
  208             $list.append(
Sampling(d->data->get_pt_curve_at_id(i)));
  211         for(
int i = 0; i<$list.size(); ++i)
  214             for(
int j = 0; j<$list.at(i).size(); ++j)
bool isDirect(void) const
Class axlPoint defines 3D points.
double vertexZ(const int &ind) const
return Z coordinates of vertex with index ind.
QVector< Edge > edgeSet(void) const
Class axlLine defines 3D lines.
axlCompositeCurveConverter(void)
~axlCompositeCurveConverter(void)
axlPoint * RotatePoint(axlPoint a, axlPoint x, axlPoint u, double alpha)
bool vertex_show(void) const
axlPoint point1(void) const
void push_back_edge(int, int)
void normalize(axlPoint &point)
QString toType(void) const
double angleOfArc(const axlCircleArc *arc)
axlPoint * secondPoint(void) const
Returns second point of the line.
bool normal_used(void) const
axlPoint center(void) const
axlPoint normalCCWArc(const axlCircleArc &arc)
bool edge_show(void) const
QString description(void) const
static bool registered(void)
axlPoint * firstPoint(void) const
Returns first point of the line.
dtkAbstractDataConverter * createaxlCompositeCurveConverter(void)
QStringList fromTypes(void) const
axlPoint point2(void) const
double vertexY(const int &ind) const
return Y coordinates of vertex with index ind.
QString identifier(void) const
void setData(dtkAbstractData *data)
static double dotProduct(const axlPoint &lhs, const axlPoint &rhs)
axlPoint * rotatePoint(double a, double b, double c, double x, double y, double z, double u, double v, double w, double alpha)
QList< axlPoint * > Sampling(axlAbstractCurve *curve)
bool face_show(void) const
axlPoint calculateNormal(void) const
bool color_used(void) const
axlPoint normal(void) const
static axlPoint crossProduct(const axlPoint &lhs, const axlPoint &rhs)
Returns the cross product between lhs (coords) and rhs (coords).
double vertexX(const int &ind) const
Return X coordinates of vertex with index ind.
void setCoordinates(double x, double y, double z)
Change coordinates of this point.
int vertex_count(void) const
Class axlMesh defines a piecewise-linear 3D object.
double angle(axlPoint vCompute, axlPoint vRef, axlPoint normal)
void push_back_vertex(const double &x, const double &y, const double &z)
Add a new vertex to the mesh.
