26 #include <dtkGuiSupport/dtkColorButton.h>
   27 #include <dtkGuiSupport/dtkSplitter.h>
   31 class axlInspectorObjectDataDynamicPrivate
   44     QVBoxLayout *layoutTop;
   49     d(new axlInspectorObjectDataDynamicPrivate)
   51     d->dynamicData = NULL;
   53     d->layoutTop =
new QVBoxLayout;
   54     d->layoutTop->addWidget(
new QLabel(
"axlInspectorObjectDataDynamic",
this));
   55     d->layoutTop->addStretch(1);
   57     QWidget *top =
new QWidget(
this);
   58     top->setMaximumWidth(295);
   59     top->setLayout(d->layoutTop);
   75     return QSize(300, 300);
   81     d->dynamicData = dynamicData;
   84     QLabel *newLabelOutput=
new QLabel(
this);
   85     newLabelOutput->setText(
"Outputs :");
   86     d->layoutTop->addWidget(newLabelOutput);
   88         QLabel *newLabel=
new QLabel(
this);
   89         newLabel->setText(d->dynamicData->outputs(i)->name());
   90         d->layoutTop->addWidget(newLabel);
   94     QLabel *newLabel=
new QLabel(
this);
   95     newLabel->setText(
"Inputs :");
   96     d->layoutTop->addWidget(newLabel);
   97     for(
int i = 0; i < d->dynamicData->inputs().size();i++){
   98         if(
axlDouble *valueInput = dynamic_cast<axlDouble *>(d->dynamicData->inputs().at(i))){
   99             QDoubleSpinBox *newBox =
new QDoubleSpinBox(
this);
  100             newBox->setValue(valueInput->value());
  101             newBox->setSingleStep(0.10);
  102             connect(newBox, SIGNAL(valueChanged(
double)), valueInput, SLOT(setValue(
double)));
  103             connect(newBox, SIGNAL(valueChanged(
double)),
this, SIGNAL(
update()));
  104             d->layoutTop->addWidget(newBox);
  105         }
else if(
axlInteger *valueInput = dynamic_cast<axlInteger *>(d->dynamicData->inputs().at(i))) {
  106             QSpinBox *newBox =
new QSpinBox(
this);
  107             newBox->setValue(valueInput->value());
  108             connect(newBox, SIGNAL(valueChanged(
int)), valueInput, SLOT(setValue(
int)));
  109             connect(newBox, SIGNAL(valueChanged(
int)),
this, SIGNAL(
update()));
  110             d->layoutTop->addWidget(newBox);
  112             QLabel *newLabel=
new QLabel(
this);
  113             newLabel->setText(d->dynamicData->inputs().at(i)->name());
  114             d->layoutTop->addWidget(newLabel);
virtual int numberOfChannels(void)
Return the number of output(s);.
Class axlDouble defines a double.
axlInspectorObjectDataDynamic(QWidget *parent=0)
~axlInspectorObjectDataDynamic(void)
QSize sizeHint(void) const
Class axlDataDynamic defines a dynamic object.
Class axlInteger defines an integer.
void setData(axlDataDynamic *dynamicData)
